just2confuzed
Ok I have got what I wanted programmed into scanner using Butel. The problem is I'm not hearing anything except State Police from Versailles, nothing from Switzerland county? Also on the scanners led should it read pri or PRI & what is the difference between the two? Also what does pid at top right mean? Do we need the attenuator on or off also do we want it in global? As you can see I need lots of help & anything you can offer is greatly appreciated! Thanks!
