Pro-197 RS 800mhz antenna and attenuator
garikfox
Queen Creek, AZ
Was wondering when I should use the "attenuator"
I use my Pro-107 in my room on a desk, It has the RS 800MHZ antenna on it, I listen to P25 simulcast system here in Mesa,AZ.
With the attenuator off the decode is 99% when analyzing the control channel
With it on it is the same 99%
Im also 3 blocks from a T-Mbile cell site and im also located 3 miles from the main P25 simulcast system tower
Should I use the "attenuator" ?
W6KRU
Vista, CA
At 99% decode, I don't see anything to be gained by using the ATT.
garikfox
Queen Creek, AZ
Ok thank you, I was just reading about overloading and such and was thinking it is overloading but eveything sounds fine still
