PRO-2006 help
sprman1955
Lavergne ,TN
Looking for the instructions bill cheek has on adjusting T1,T4,T7,T6,T5,,T8.Do not need the whole book. Working on a old Pro 2006 A thats not moded. Thanks :)
Ubbe
Stockholm, Sweden
This is the original service instruction, don't know if Bill had something else as it will need a signal generator.
  • Pro2006.pdf
sprman1955
Lavergne ,TN
Thanks i forgot to say i have the service manual.Bill used a meter as i remember and used a weather station to make the adjustments and used a chip for test point one. I used to have the book but sold it.
Ubbe
Stockholm, Sweden
You can measure the voltage at pin 14 of IC4 and tune to max voltage. Set the receive mode to AM.
It's always difficult to use a live signal as it will change in strength depending of propagation and signals bouncing around and reflect off objects.
/Ubbe
Ubbe
Stockholm, Sweden
The service manual has the other info about TP1 and TP2 where you measure the DC voltage, 3,8v and 3,9v, to tune the 10,7MHz and 455KHz IF filters frequencies, as there's no way to calibrate the reference oscillator if it has drifted away in frequency.
/Ubbe
sprman1955
Lavergne ,TN
Got the scanner working great now.Did all the adjustments ,scanner now receives great! Was way out of adjustment.Thanks for all the help with it! :)
wtp
Port Charlotte FL
just keep the light dim or off.
i have a 2004 that has been in use since i got it and sure it is a little dull on high, but i can still read it.
i have always kept it on dim as i usually don't have to see it.
sprman1955
Lavergne ,TN
Yes mines 30 years old yet works great.I hear you about the light.I have seen the pro 2006 for sale at hamfest her for $60.00 this summer.
  • Like
Reactions: wtp
