PRO 2036, repairable?
royboy2
I have a 10 year old PRO 2036, retired. I replaced it with a BC898T and they ook identical.
Problem wirh old one is an annoying breakup of message everywhere with some times humourous results.
Has anybody else experienced this, I would like to kkep the radio as it is perfect in all other respects?
Thank you
royboy2[/b]
mciupa
Canadian DB Admin
Moderator
I'm here a lot
royboy2 said:
Problem with old one(Pro-2036) is an annoying breakup of message everywhere with some times humourous results.
I'd say if you need a laugh, listen to your 2036 :lol: .A 200 channel non-trunker is so inadequate nowadays . Enjoy your 898T !
Al42
Long Island, NY, USA
It sounds as if something's loose - possibly a bad solder joint. Or a component is intermittent.
First step - assuming you want to fix it - is to find out where it's losing signal - which stage. Then you'll know where to look.
royboy2
I have two replies to my query about a 10 year old PRO 2036, the second was definitely useful, the first is of uncertain value given the still numerous non trunker radios available new.
I am working on getting the 898 to do it's thing, I also am trying to decipher the manual for my new Icom R20. Now, that's funny.
Thankyou both
royboy
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Sorry for the flippant reply royboy2 . :oops:
I hate to be-leaguer the point,( seeing as you ended the thread )
but , I'm assuming that you were not going to be doing the repair
work yourself. Sending the radio to a RadioShack repair facility will cost
you $49 to put it on the bench .
I just can't see that radio being worth that much in today's market.
Now that I've stated my opinion, I'll go back to my corner. :wink:
You have an Icom r-20 ? ! I'm jealous ! :mrgreen:
MacombMonitor
Bad news! The Radio Shack PRO-2036 is the same as the Uniden BC890XLT. It wasn't even good when it was new. It has problems with images, birdies, and intermod. :( Bob Parnass did a review on the BC890XLT in Monitoring Times, June 1995.
DaveH
Ottawa, Ont.
Methinks those who might have owned a BC890/PRO-2036 (or may still ) would be
less inclined to berate it. For an older scanner, it offers great functionality. The weak
point is its RF front-end which has great problems when connected to a rooftop
antenna. This is not unique, my BC780 on VHF/UHF has problems with this.
What's not clear is whether this "breakup" is due to a defect, or is a normal
case of overload. In the latter case, any money spent on repair would be wasted.
As for lack of trunking capability....big deal. Why tie up an expensive trunked
(digital) scanner listening to some conventional frequencies? This scanner was
discontinued about 10 years back. Everything gets old! Even great old scanners
like the PRO2004/5/6 are becoming more limited due to narrowbanding.
My old BC890 has a discriminator tap used to monitor trunked data channels.
Once the signal level is controlled, it works OK (using filter or attenuator). I scan
LTR systems conventionally, and search the lowband (using search/store) etc.
It can sit on a conventional channel for days, maybe weeks.
I picked up an old BC148XLT for $10...10 channels, no CTCSS, no 800MHz,
no search function...etc. Was it worth it...for me, yes. For a price, things can find
their niche.
I agree that sometimes the cost if servicing equipment makes it not worth fixing.
Try the following: partly straighten out a paper clip and insert into the antenna
BNC. If the signals you want are still there (even noisy) and the breakup improves,
the problem is overload. If it continues, and you are inclined towards simple
servicing (of obvious things; broken wires etc.), open it up and have a look.
Dave
royboy2
pro 2036 Repairable?
Thank you for all replies, and I was not trying to demean mciupa, my manner of expression is sometimes difficult to interpret as simple text.
I intend to fiddle around it for a while just to be curious. If it dies in surgery I will give it it's own little recycle box. If it makes a recovery well, I have two grandsons who will listen to it and be thrilled to bits.
In almost 10 years it never played up, lucky I guess.
How I came by the R20 is a story on it's own, but it is taking major patience and studying to make it work, and it's not even a reunker
Kind regards to all
royboy
