Pro-2040 trunk track?
hawkeye32
Windsor
Just wondering if the pro-2040 is able to track any trunking systems. After reading the manual and such online, I am assuming it does not trunk track, just want some clarification.
Thanks!!
ecps92
Taxachusetts
hawkeye32
Windsor
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I think -I'm not entirely sure here - that this is the base clone that RS made of the original Uniden trunktracker, the BC235. It can trunktrack Moto analog Type 1 or 2 systems - but in this early stage, it can only trunktrack or scan conventionally, but won't do both like modern scanners can.
Mike
ecps92
Taxachusetts
Not having used one, but reading between the Lines, the answer is
ONLY if ALL the frequencies are within the Ranges posted in the manual
Let us know how you make out tho
Thanks!! Ya read the same manual, I guess I should of clarified better. Will it track say a Motorola type 2 system? I know it can't do digital.
hawkeye32
Windsor
Mike
Ok Thanks!! That's what I thought but wasn't sure lol. I do believe their are a couple of old analog systems that are active here in Windsor area.
hawkeye32
Windsor
Yes sir, will do. If it don't pan out, was free anyhows. Maybe set it up for a civil. air scanner.
pro92b
Mutated Member
Mike
The BC235 and PRO-90 are twins. The PRO-2050 is a base scanner with similar capabilities. The PRO-2040 looks to be just a conventional scanner with no trunk tracking capability.
