Pro-2043
#1
Hi all. I am using a PRO-2043 and live in the Southwestern area, just south of London and was wondering if anyone could be kind to pass on some strong interesting frequencies they have come across that will work with my scanner. Too bad I don't have a digital scanner as it seems there are a lot of frequencies out there that are digital and I may be missing out.
Thanks for your time
hockeypucks
Forts
Ontario, Canada
#5
I'd suggest heading over to the database and checking out the Middlesex and Elgin county entries. Lots of good stuff for you there. Also, depending on your reception you may want to look at Chatham/Kent and Oxford.
