pro 2096 no receive
balou
ontario
ok it was working ok...it was in my truck i also have my yaesu 7900r in there as well my antennas are fairely close together
i usually shut the scanner off when using the 7900r but a few times i forgot it on could this cause the scanner to malfunction
i have no more receive...i tried my other one to make sure it wasnt my antenna but the scanner works fine
what would you suggest i look at first
thanks
tonyclark
Graceville, Florida
Really sounds like a solder joint on the board needs to be resoldered. Have you opened the radio up to check where the antenna is soldered to the board?
balou
ontario
i opened up the case but theres a steel plate over the connection...i didnt go to far looked too much for my skills
tonyclark
Graceville, Florida
I see what you mean. I have a pro2054. They are the same except what they receive. Hope you can get it fixed. Wish I could help you more.
Tony
