Pro-2096 vs Pro-96
jehm1212
Hanover County, VA
I've heard a lot of comparison between the Pro-96/2096 and other scanners. But how do they compare to each other? Is the 2096 any more/less sensitve than the 96? Does it ovelroad as easily? I hooked up my 96 to my newly installed 800MHz antenna on my truck, and was a little surprised. I guess it was overloaded because the signals got worse. Using my 396, the signals get much better. Thanks for your help.
rananthony04
Greater Los Angeles Area
I have a pro-96 and a 2096, which is mounted in my tahoe. I also use the stock glass mount antenna that they "recommend" you buy with the 2096. I have had NO problems with either one. When stationary, I would press the scan button at the same time (I have them both programmed identically) and both scanners land on each channel in perfect synchronization. Hope that helps.
-Robert
Los Angeles
