Pro 2096's
#1
I have two radio shach pro 2096's and I find that one that is actually the newer one is a little more sensitive and picks up some of the weaker frequencies then the other one. Am wondering why this would be, off exactly the same outdoor antenna, is setup as a base scanner. Both have exactly the same firmware. Any one know what could be up with this. Thanks for all your help.
Thayne
#2
Sometimes that happens; it just ended up aligned better.
Unless you know a shop that is capable of "super-tuning" radios I wouldn't worry about it.
