PRO-39 issues
motorhommie
Yuma AZ
I am a licensed Tech but new to the scanner world. I was gifted a Realistic Pro-39 Hyperscan and am having issues programing it. The device works, Scans through all 200 channels but there are no frequencies I can see on the window as it rapidly searches. When I attempt to input a freq, it locks up after the 1st digit is inputted. ???
rhodester
Saratoga County, NY
kc2asb
NYC Area
Sounds like it's scanning through empty channels "000.0000 MHz". Turn the radio on, press MANUAL to stop it from scanning, then press PGM. Enter the frequency, including the decimal "." and then press ENTER to store the frequency.
motorhommie
Yuma AZ
Thank you. I did exactly what you said. Manual stops on a channel, the freqs are zeroed out. After pushing the PGM key no digits populate. Then as i keep trying different numbers a digit will pop in and no further digits can enter.
I watched a repair video where the battery and back were removed and “junk” was removed from affected key locations.
I am thinking that is my next move.
BTW what is the MHz range for this device?
JUST FOUND IT!
30-960MHz with specified ranges within.
kc2asb
NYC Area
JUST FOUND IT!
Oxidized keypad contacts would make sense where the keys are not responding when pressed. Good luck with the repair, and keep us posted!
motorhommie
Yuma AZ
to get the idea.
hit manual
then hit 1
hit program
type in 162.55 (don't forget the decimal point)
hit enter.
might have to adjust the squelch and volume.
I disassembled the radio having removed the battery. Cleaned the contacts, cleaned the back side facing the battery where the keypad is. I can not see how to get that board off even with all the screws and knobs out. The anteana has a nut that could come off but I didn't see that would help. Also I could not get the wiring group connectors (2) off the board. I sent an email that I don't expect an answer from Tandy National Parts. The keypad only beeps on certain numbers, it is clearly defective and noted in their info:
GRE-Built Portables: Worn Out Keypads​
The keypad on late model GRE-made Radio Shack portables, e.g., PRO-39 and PRO-43, can become unreliable after prolonged use. The best repair is to replace the rubber keypad instead of trying to restore contacts using chemicals. A replacement rubber keypad may be ordered inexpensively through Tandy National Parts or your local Radio Shack Store.
kc2asb
NYC Area
I don't think Tandy Corporation/Tandy National Parts exists anymore after Radio Shack went bankrupt. The Radio Shack brand still exists, but it is under new ownership and has no connection to the old Tandy/Radio Shack.
It's doubtful a parts inventory exists for any old Radio Shack products. The PRO-39 is a 1990's vintage scanner and the replacement keypads probably sold out long ago. GRE itself no longer exists.
One option would be to look for a parts radio, but it would be a roll of the dice, as there is a good chance the keypad would exhibit the same issue.
You can try contacting G&G Communications. They repair scanners and have scanner parts available for sale. You never know, they might have a replacement keypad kicking around.
G&G Communications:
kc2asb
NYC Area
Never mind - the PRO-39 keypad is on G&G's list of parts no lo longer available
As of 2/9/2013: Radio Shack Parts No Longer Available
PNMAKEMODELDESCNOTESDATE
12410841Radio ShackPro-96Carbon Keypad
1/29/2011​
12100442Radio ShackPro-92Battery Holder NiCadNicad Battery Holder
2/23/2011​
10789824Radio ShackPRO39KEYBOARD
2/22/1997​
10788107Radio ShackPRO2006KEYBOARD
1/10/1998​
11211737Radio ShackPro-39Top EscutcheonDiscontinued Part
7/15/2001​
1184959Radio ShackPro-39Front Panel Complete
7/15/2001​
11184959Radio ShackPro-39Front Panel Complete
7/15/2001​
1184967Radio ShackPro-39Rear Cover Case Complete
7/15/2001​
12193876Radio ShackPro-92Battery Holder - Alkaline
10/7/2005​
12228805Radio ShackPro-96Battery Holder RechargableColor Yellow
4/26/2007​
12219176Radio ShackPro-94Battery Holder - Hinged DoorAlkaline or Nicad
3/2/2007​
12424677Radio ShackPro-83Speaker
2/12/2013​
12461653Radio ShackPro-106Squelch Knob
2/12/2013​
12461661Radio ShackPro-106Volume Knob
2/12/2013​
12441945Radio ShackPro-197Squelch Knob
2/12/2013​
12441937Radio ShackPro-197Volume Knob
2/12/2013​
12219283Radio ShackPro-94Keyboard
2/12/2013​
12357752Radio ShackPro-96LCD Display
2/12/2013​
10616621Radio ShackPro-51Battery Door Assembly
2/12/2013​
12424685Radio ShackPro-83Battery Door Cover
2/12/2013​
