PRO-404 Weirdness
twexzer
Northampton, MA
Hi!
If I turn on my PRO-404 and quickly hit the program button, it says "Load-Fr" "Yes- Ent" "No- Clear".
I pressed ENT for yes.
It then loaded my scanner 100%, all 200 channels appear to be loaded (randomly?) with HAM frequencies stretching all bands... any ideas?
Thanks!
Sam
Benzman66
Lancaster County, PA & Pittsburgh, PA
Yes, that is normal when you hit those keys.
The newer scanners come with 150 to 200 of the most common pre-loaded frequencies at the factory. What you did is a factory restore, so you will have to re enter what other local frequencies you may have had programmed as they are now gone.
If that happens again by accident, just hit clear when it asks yes or no. That way all your own programming will stay intact.
