Pro 404
Mtnrider
Greene County New Yawk
A friend got one for christmas and want me to get the programming fixed...i have the 20-047 cable and need to know A) what program works best B) will this do the newer highband frequencies ? like 151.4825...before i even bother...thanks in advance
RonnieUSA
Rowan County,KY (Morehead)
From the RadioShack PRO-404 200-Channel Handheld Scanner (User's Guide) dated January 21, 2013
Specifications
Frequency
Coverage
(MHz)
10 Meter Amateur Radio
29–30 (in 5 kHz steps)
VHF Lo
30–50 (in 5 kHz steps)
6 Meter Amateur Radio
50–54 (in 5 kHz steps)
Aircraft
108–136.9875 (in 12.5 kHz steps)
Government
137–144 (in 12.5 kHz steps)
2 Meter Amateur Radio
144–148 (in 5 kHz steps)
VHF Hi
148–150.8 (in 12.5 kHz steps)
VHF Hi
150.8-162 (in 5 kHz steps)
VHF Hi
162-174 (in 12.5 kHz steps)
Amateur Radio/Government
380–450 (in 12.5 kHz steps)
UHF Standard
450–470 (in 12.5 kHz steps)
UHF “T”
470–512 (in 12.5 kHz steps)
Channels of Operation
200 channels
Sensitivity
(S+N)/N
20
dB
29–54 MHz
0.5 uV
108–136.9875 MHz
1.0 uV
137–174 MHz
0.5 uV
380–512 MHz
0.7 uV
Spurious Rejection (FM @154 MHz)
50 dB
Additional Info
Selectivity
±8 kHz
–6 dB
±17 kHz
–50 dB
Search Speed
Up to 80 Steps/Sec
Scan Speed
Up to 40 Channels/Sec
Delay Time
2 Seconds
IF
Frequencies
1st IF
10.7 MHz
2nd IF
455 kHz
IF Interference Ratio (10.7 MHz)
70 dB at 154 MHz
Squelch
Sensitivity
Threshold
Less than 0.5 uV
Tight (FM)
(S + N)/N 25 dB
Tight (AM)
(S + N)/N 20 dB
Antenna Impedance
50 Ohms
Audio Output Power (10% THD)
180 mW Nominal
Built-In Speaker
1 3/8 Inches (36 mm), 8 Ohms
Operating Temperature
14° to 140°F (–10° to 60°C)
Power Requirements
4 AA Batteries
9V AC Adapter (not supplied)
9V DC Adapter (not supplied)
Current Drain (Squelched)
45 mA
Dimensions (HWD)
5
Ð
x 2
È
x 1
Ï
In
(145 x 63 x 40 mm)
Weight (without antenna)
approx. 7.8 oz (220 g)
Specifications and depictions are subject to change and
improvement without notice. Actual product may vary
from the images found in this document.
So It looks like yes.
nanZor
Butel's ARC404 may be worth looking into.
No, you will not be able to program 151.4825, it will round off to 151.480. However, you may still be able to hear it programmed like this with a lower audio level, and if there are no other nearby channel users.
Note that the sensitivity levels listed above are slightly mis-separated - ie the airband sensitivity is 1uv, not as good as .5uv. NOT a super big deal, and appreciate the data, but just wanted to point this out if someone was spec-shopping a radio and took a casual glance.
