Pro-433 Error entering frequencies.
#1
Hey, guys, I got a Pro-433 for my birthday this weekend and I am having a minor problem. When I try to program a frequency in any bank, I occasionally get an ERROR after punching in the frequency. Currently, I am trying to get 460.325 in on Bank 3 Channel 1, so I hit E/PGM then 460 ./CLR 3250 then E/PGM and it beeps ERROR at me. What did I do wrong?
Marietta, Ohio
#2
Sounds like you are doing it right, I did what you did here and it worked fine. Does the PGM show on the display after you push E/PGM and beep to confirm?
