pro 433 talkgroups
Spring Valley NY
#1
Wirelessly posted (BlackBerry8530/5.0.0.654 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/389)
Hi I just figured out how to program trunked frequencies into this scanner my question is would I be able to scan just the stored talkgroups instead of going through all of the frequencies?
Thanks.
#2
Thanks.
There are two trunking modes, SCAN and SEARCH.
SEARCH allows you to hear all active talk groups.
SCAN allows you to hear only the talk groups you have programmed into the scan lists.
