pro 433
Virginia Beach, Va
anyone here have one that is having problems getting talk groups???
i have 2 pro 97's and they pick up fine on talk groups..
some people say if i am getting talk groups all the time on the 97's i should be on the 433 and i am not.
i'm sure its not set up wrong, i had some one else on here help me set it up.
I thought the scanner was messed up so i took it back and exchanged it and this one does the same thing.
read this link to help ya out before posting
http://www.radioreference.com/forums/showthread.php?t=81091
any info be great.
http://wireless2.fcc.gov/UlsApp/UlsSearch/licenseLocSum.jsp?licKey=1302249
n2mdk
Ames, IA
I believe your trying to listen to an EDACS system are the channels programmed into the proper channel numbers in the proper order.
This was posted to the wrong thread I finally realized.
Virginia Beach, Va
lets see if i can get some info here, here in the link for the pro 433 manual
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000433_PM_EN.pdf
i got mine set up from pages 24 to 26, tell me if that is correct.
my controls channels are set on bank 3, i got the talk id set on bank 3.
now on page 29-- status bit, do i need to change that?????
and on page 33 programming base and offset freq. do i need to do that??
the pro 97 was easy o set up...
kd5dga
Killeen,Texas
Since the 433 is aUniden built scanner the radio should be set to control channel scan only.So program up the channels in order/out of order.Select in the trunking settings in ARC433 under motorola 800/900 with status bit on and control channel scan.This works much better.I have this set for a type 1 system and having great results, except that I had to find out what fleet map to use.This is not a issue for type 2 systems.
Read this artical;
http://wiki.radioreference.com/index.php/Control_Channel_Only
