pro-46 help
i need a charger and a rechargeable battery for this scanner i just bought. i got regular AA rechargeable batteries but the generic car charger thing i got with various adapters wont charge the AA's. so what I'm asking is where i could get replacement stuff for an older scanner like that?
kevin390
Wallkill, NY
Pro-46
I have a pro-46 that works great but the "shell" was in rough shape. I called G & G communications at 585-768-8151 and bought a " shell " for 15 dollars. They have parts for lots of old scanners and sell new and used scanners. Good people to do business with.......Ray
mcema699
The listed power supplies for this scanner I think have been discontinued. RS will have replacement models available.
If you are comfortable with understanding voltage, amps and tip polarity, you can buy from other retailers as well.
PRO-46 (200-0305) Using Other Power Sources Faxback Doc. # 3594
IMPORTANT INFORMATION ABOUT THE EXTERNAL POWER JACKS
The scanner has two external power jacks - POWER and CHARGE. It is
important that you understand the purpose of each jack before you connect
any adapter to the scanner.
The POWER jack powers the scanner and disconnects the internal batteries.
You can use this jack with an external power source (AC or DC Adapter)
regardless of the type of batteries you install.
The CHARGE jack supplies power to operate the scanner and also charges the
internal batteries. Use the CHARGE jack only when you install
rechargeable nickel-cadmium batteries.
WARNING: Never use the CHARGE jack with non-rechargeable batteries. If
you try to recharge non-rechargeable batteries, they become very
hot and could explode.
USING AN AC POWER SOURCE
To power the scanner from AC power, you need Radio Shack's AC adapter,
Cat. No. 273-1665. Plug the adapter's barrel plug into the scanner's POWER
jack. Then plug the adapter's power module into a standard AC outlet.
When you finish using the AC adapter, disconnect it from the AC outlet
first. Then disconnect it from the scanner.
NOTE: If you have installed rechargeable nickel-cadmium batteries in the
scanner, you can connect the AC adapter to the CHARGE jack. This
powers the scanner and recharges the batteries at the same time.
See "Charging Nickel-Cadmium Batteries."
USING A DC ADAPTER
NOTE: Mobile use of a scanner may be unlawful or require a permit in some
areas. Check the laws in your area.
You can power the scanner from your vehicle's battery power, provided the
vehicle has a 12-volt, negative ground electrical system. To do so,
you need Radio Shack's DC Universal Adapter, Cat. No. 270-1560A.
1. Connect the adapter's orange barrel-plug to the adapter's cable with
the tip set to - (negative).
2. Set the adapter's voltage switch to 9V.
3. Insert the barrel plug into the scanner's POWER jack.
4. Plug the other end of the adapter into your vehicle's cigarette-
lighter socket.
When you finish using the DC adapter, disconnect it from the cigarette
lighter first. Then disconnect it from the scanner.
NOTE: If the scanner does not operate properly when you use a DC adapter,
unplug the adapter from the lighter socket and clean the socket to
remove ashes and other debris.
CHARGING NICKEL-CADMIUM BATTERIES
The scanner has a built-in charging circuit that lets you recharge nickel-
cadmium batteries (Cat. No. 23-125) while they are in the scanner. To
charge the batteries, simply connect an AC adapter (Cat. No. 20-188) or a
DC Universal Adapter (270-1560) to the scanner's CHARGE jack.
WARNING: Do not connect either adapter to the scanner's CHARGE jack if
you have installed non-rechargeable batteries (standard, extra-
life, or alkaline). Non-rechargeable batteries become hot and
can even explode if you try to recharge them.
It takes about 10 to 18 hours to recharge batteries that are fully
discharged. You can operate the scanner while recharging nickel-cadmium
batteries, but the charging time is lengthened.
Charging Tips
Nickel-cadmium batteries last longer and deliver more power if you
occasionally let them fully discharge. To do this, simply use the scanner
until the low battery indicator appears on the display. Then fully charge
the batteries.
(ALL-12/13/94)
Privacy Policy
