Pro 62 Operations manual
Hollister, CA, USA
I have a very old Pro 62 scanner that I would like to use again. I lost the original manual and I have read the brief on-line instruction manual at the Radio Shack site. However, lots of details are not covered. Would anyone know where I could get a copy or a download of the original manual?
Thanks.
Hollister, CA, USA
Thanks!
I appreciate the help, PR. The "wrong" answer is still very helpful though it is one model different. I had found the other instructions that you sent as the right answer, but they didn't have much on operation and advanced programming. I can probably figure out the necessary steps with the "wrong" manual you sent. Thanks!
