Pro-668: Pro 668 - Not receiving digital/trunking anymore
dsjab_3
Maryville, TN
I was using the programming software to rearrange some playlists, and something has gotten messed up to where my digital channels are no longer coming in. I did not mess with any settings or play sets. My original goal was just to move some channels to different playlists but now only conventional freqs will come in.
What could have gotten messed up between copying the data from the software to the scanner?
tvengr
Well Known Member
Baltimore County, MD
Can you please attach your programming file and I will check it for problems. Which systems and agencies are you monitoring?
dsjab_3
Maryville, TN
Thanks for the reply but after extensive research I discovered the issue. The trunking system got switched from Project 25 to Motorola somehow.
