Both my DSP and CPUS seem to be stock. Has anyone seen any updates?
There were two updates. First fixed the EDACS bug, and second recalibrated battery meter
Current:
UP app ver-2.3
DSP app ver.-1.3
DSP VOC ver-1.6
I believe those updates were only for the PSR-800 and WS1080. I have the same exact version numbers and the EDACS patch bug is definitely present. The battery meter was also not re-calibrated but I did change the values that were from another posting. If you check the release notes, there is no mention of fixing any of those bugs or any further updates since 2.3 which came out August 2014.
You can update your pro-668 with ws1080 firmware.I have the ws1080 and pro-668,now i have the ws1080 and what i call the whistle-shack1080.
Can you confirm that you have actually updated a 668 with 1080 firmware? CPU or DSP?
Last i have heard, multiple people say updating a radio shack model with whistler model will "brick" the radio , as they have different splash screen start up etc... functionally the same though!
Yes,When the pro-668 boots up no more radio shack logo.its now whistler logo and firmware 2.6.To do this one needs to locate and download ws1080 firmware directory.Then get iscan software to accept it.All GEROM,WHISTLER and RADIO SHACK FIRMWARE ARE ALL ON THE SAME SEVER LOCATION.
If you did get the firmware to work, then show us a picture of scanner. just push menu button when scanner powered off and hit power, so we can see firmware that was installed. If you can't then most are going to assume it didn't happen.Yes,When the pro-668 boots up no more radio shack logo.its now whistler logo and firmware 2.6.To do this one needs to locate and download ws1080 firmware directory.Then get iscan software to accept it.All GEROM,WHISTLER and RADIO SHACK FIRMWARE ARE ALL ON THE SAME SEVER LOCATION.
So whats the link to the server?
Bill Cheek would be proud.
