pro-79
Gooner1959
Am hoping somebody can help me with a pro-79 problem i have.
When i turn it on there is a small crackle at the speaker as if its turning on but the display is blank, it doesnt scan & the keypad appears dead.
Are there any common faults with this model that could cause this?.
Mike
thesavo
Schenectady, NY
If you don't mind loosing the stored frequencies, you can try a reset or re reinitialize. Though I think you have a bad trace.
The reset procedure isn't the same as others. Others say hold the [2] and [9] buttons and turn on.
This is different. Also, I could only find an owner's guide. No service manual.
I think reseting saves frequencies and initialize clears them.
Perhaps someone else will be able to say what other model your pro 79 shares and if it has a service manual, you may be able to use that.
