While you can't directly download the data from the RR database, you can use MS Excel (or many other spreadsheets) to copy the RR database, modify it to match the Win92 format and past the data into Win92. This should save you quite a bit of time and trouble (and nearly eliminate they nearly certain typos from manual entry).
For example, copy the data from "LA County FD Battalion Response Map", which will look like this
Frequency License Type Tone Alpha Tag Description Mode Tag
470.56250 KNP331 RM CSQ LAC BLUE 1 CMD LA Basin - Bn 7, 8, 9, 14, 18 (South County & Catalina) FM Fire Dispatch
470.43750 KNP331 RM CSQ LAC BLUE 2 Alt CMD/Tac - LA Basin FM Fire-Tac
470.61250 KNP331 RM CSQ LAC BLUE 3 CMD LA Basin - Bn 1, 3, 5, 13, 20 (West County) FM Fire Dispatch
470.51250 KNP331 RM CSQ LAC BLUE 4 Countywide Admin / Alt CMD FM Fire-Tac
470.66250 WII225 RM CSQ LAC BLUE 5 Alt CMD/Tac - San Gabriel Valley FM Fire-Tac
470.41250 WII225 RM CSQ LAC BLUE 6 CMD San Gabriel Valley - Bn 2, 4, 10, 12, 15, 16, 19 (East County) FM Fire Dispatch
470.46250 KNP331 RM CSQ LAC BLUE 7 Alt CMD/Tac - San Gabriel Valley FM Fire-Tac
470.53750 KNP331 RM CSQ LAC BLUE 8 Countywide Dispatch FM Fire Dispatch
470.63750 KNP331 RM 151.4 PL LAC BLUE 9 Alt CMD/Tac - Antelope Valley ONLY FM Fire-Tac
470.36250 KNP331 RM 151.4 PL LAC BLUE 10 Alt CMD/Tac - Antelope Valley ONLY FM Fire-Tac
470.58750 KNP331 RM CSQ LAC BLUE 11 Alt CMD - Santa Clarita & Antelope Valleys FM Fire-Tac
470.48750 KNP331 RM CSQ LAC BLUE 12 CMD North - Bn 6, 11, 17, 22 (North County) FM Fire Dispatch
453.67500 KBZ726 RM 151.4 PL LAC BLUE 13 CMD La Habra - Bn 21 FM Fire-Tac
453.72500 KRM765 RM 151.4 PL LAC BLUE 14 Crew / Dozer Net FM Fire-Tac
453.77500 KMG240 RM 151.4 PL LAC BLUE 15 Alt Crew / Dozer Net FM Fire-Tac
453.82500 KBZ725 RM 151.4 PL LAC BLUE 16 CMD/Tac FM Fire-Tac
453.97500 KM6542 RM 151.4 PL LAC BLUE 17 CMD/Tac FM Fire-Tac
453.90000 KBN492 RM 151.4 PL LAC BLUE 18 Tac (North County) FM Fire-Tac
478.55000 WQJX500 M CSQ LAC BLUE 19 CMD/Tac Direct FM Deprecated
478.65000 WQJX500 M CSQ LAC BLUE 20 CMD/Tac Direct FM Deprecated
478.75000 WQJX500 M CSQ LAC BLUE 21 CMD/Tac Direct FM Deprecated
478.85000 WQJX500 M CSQ LAC BLUE 22 CMD/Tac Direct FM Deprecated
478.95000 WQJX500 M CSQ LAC BLUE 23 CMD/Tac Direct FM Deprecated
478.98750 WQJX500 M CSQ LAC BLUE 24 CMD/Tac Direct FM Deprecated
478.55000 WQJX521 RM 151.4 PL LAC U-19 Command / Tactical / Portable Repeater FMN Fire-Tac
478.65000 WQJX521 RM 151.4 PL LAC U-20 Command / Tactical / Portable Repeater FMN Fire-Tac
478.75000 WQJX521 RM 151.4 PL LAC U-21 Command / Tactical / Portable Repeater FMN Fire-Tac
478.85000 WQJX521 RM 151.4 PL LAC U-22 Command / Tactical / Portable Repeater FMN Fire-Tac
478.95000 WQJX521 RM 151.4 PL LAC U-23 Command / Tactical / Portable Repeater FMN Fire-Tac
478.98750 WQJX521 RM 151.4 PL LAC U-24 Command / Tactical / Portable Repeater FMN Fire-Tac
Copy the "Frequency", "Tone", and "Alpha Tag" columns into a new area of the spreadsheet. They need to be reordered and an extra column added. The final destination should be "Alpha Tag", "Frequency", (a new column added called) "Rx Mode", and "Tone".
Next, edit the "Tone" column to blank out the "CSQ". For those entries, populate the "Rx Mode" column with the text "FM".
Next, edit the "Tone" column to remove the " PL" from the columns that have this populated (e.g. "151.4 PL" would become simply "151.4"). For those entries, popluate the "Rx Mode" column with the text "PL".
Now that the data has been cleaned up and is ready for loading into Win92, it should look like this:
Alpha Tag Frequency RX Mode Tone
LAC BLUE 1 470.56250* FM
LAC BLUE 2 470.43750* FM
LAC BLUE 3 470.61250* FM
LAC BLUE 4 470.51250* FM
LAC BLUE 5 470.66250* FM
LAC BLUE 6 470.41250* FM
LAC BLUE 7 470.46250* FM
LAC BLUE 8 470.53750* FM
LAC BLUE 9 470.63750* PL 151.4
LAC BLUE 10 470.36250* PL 151.4
LAC BLUE 11 470.58750* FM
LAC BLUE 12 470.48750* FM
LAC BLUE 13 453.67500* PL 151.4
LAC BLUE 14 453.72500* PL 151.4
LAC BLUE 15 453.77500* PL 151.4
LAC BLUE 16 453.82500* PL 151.4
LAC BLUE 17 453.97500* PL 151.4
LAC BLUE 18 453.90000* PL 151.4
LAC BLUE 19 478.55000* FM
LAC BLUE 20 478.65000* FM
LAC BLUE 21 478.75000* FM
LAC BLUE 22 478.85000* FM
LAC BLUE 23 478.95000* FM
LAC BLUE 24 478.98750* FM
LAC U-19 478.55000* PL 151.4
LAC U-20 478.65000* PL 151.4
LAC U-21 478.75000* PL 151.4
LAC U-22 478.85000* PL 151.4
LAC U-23 478.95000* PL 151.4
LAC U-24 478.98750* PL 151.4
Next select the 4 columns of data (but not the headings row) in the spreadsheet and copy them (ctrl-c or appropriate). Move to Win92 and select the row where the first of them is to be placed. Plaste the data onto the Win92 screen and check for any errors. Correct any errors and populate any options from the 4 columns we didn't populate.
Repeate this process for the other banks and save the file locally (so you can simply make changes later if needed) and upload the data to your scanner.
Please note that the amount of data you can copy is limited by the Win92 screens (which reflect the scanner limitations). You can only copy up to 50 frequencies per bank. To descide what values to enter in the "Rx Mode" col, simply look at the Win92 values for that field and pick the one that's appropriate. While I didn't provide details, you can populate the talk groups for trunked systems using a similar procedure.
