PRO-94 won't accept EDACS Talk Group IDs
Tampa
#1
I'm new to the scanner arena, can someone please help me figure out how to program my PRO-94 so I can listen to my local FD? Thanks
SAR923
#2
Where do you live, exactly? As in the exact state, county, and city? We can't help you without knowing what system you are trying to program.
Jackson Square, East Weymouth, MA.
#3
I don't bother with entering the talk groups manually, I just let the radio scan and as the talk groups activate, I let the radio allow them to populate the list. If there is something I don't want to listen to, I hit the lockout button. Since you are new, that is probably the best for you right now. Once you have entered the frequencies in proper Logical Channel Number sequence, just let the radio do it's magic. Not all talk groups are active, in fact it may take months before you actually hear every single one. Some are not even used at all for whatever reason. Here is a tutorial on programming: http://support.radioshack.com/support_tutorials/communications/200-0524/67777.htm
The easier to read manual is here: http://myweb.cableone.net/marksscanners/94AB/94AB.html
