Spadinator
I have been using Trunk88 with my Pro95 and had a computer upgrade. Now I can't get it to work. I have tried to set it up for the Pro95 but no longer see that option. Any ideas?
If the discriminator itself (or some other part of the scanner) is bad, you won't be able to hear a clean signal in the speaker - even on a close clean signal. If you can, redo the tap with new components. (The audio from the tap point is the audio you hear in the speaker after some filtering and amplification.)I guess my Pro-95 is toast for using as a source for trunk88.
The main purpose of the 10K resistor is to provide some isolation between the discriminator chip and the outside world, so that if accidently short the audio lead to earth/chassis, you won't damage the discriminator chip.. . . Should I attach the 10K resistor like is done on other scanner taps?
If you're doing IF filtering (a 2-4pf cap after the resistor), it won;t work without the resistor. (The short-protection is just a bonus.) Whether you need to filter the IF depends on where you're sending the discriminator audio (a slicer or a computer sound card) and whether the particular scanner bleeds IF into the discriminator output. Without a scope (even a cheap old one) you have no way of knowing what the signal looks like.I am NOT using any resistors on the discriminator output of my scanners (including PRO-95) and not had a problem. I can't imagine a scenario where someone is shorting out that signal as long as you use regular audio cables and only connect/disconnect them with the power off.
