Pro-96 battery pack won't close
#1
I bought a used Pro-96, and when I put in the batteries, the tray won't close as the pack with the batteries seems just a bit too fat. What's going on here? Closes fine without the batteries.. Is this a wrong battery pack to this scanner? I also have a Pro-97 and the black battery pack is identical to the 96.. Is the battery pack suppose to be smaller in the 96?
#2
Ahhh finally got it, had to push it down and then slid it in, was used to my Pro-97 slidding right in there...
