Pro-96 CPU version
#1
What is the newest CPU version of this scanner? What is the difference between each version, is there something an older version won't receive and a newer CPU will?
Then there is the DSP version but from what I understand it can be easily downloaded from the RadioShack's website.. Would I need special software to program the newer DSP version into the Pro-96?
#4
According to the Wiki, the Pro-96 is rebanding supportable. Is this confirmed? In what way will I have to get it upgraded, by a downloadable new DSP version or have to send it to RS?
#5
as far as rebanding , no one really knows. But should be ok using / setting the tables ... from what I have picked up on here
