pro 96 DSP LOAD
ve5wil
Moose Jaw
#1
Apologies if this was asked before, i missed the thread if so.
A friend pro 96 has suddenly seemed to develop a problem.
The unit seems to be locked in a loop
Turn unit on and this is what happens
1st screen ----
DSP LOADING
Boot F1.0
2nd screen
DSP LOAD
PC/IF Port
Flash Mem
Then unit freezes here.
Tried reset button no luck...
previous time when this happened, the problem was cleared by loosening the back screws a notch. This time that hasent even helped.
even locked in this screen, computer wont talk to radio.
Any ideas?
Wil
S.E. MI
#4
If loosening the screws worked in the past it sounds like the board is shorting out against something inside OR the main board has a crack. I would take it apart and try to find the problem, it might be obvious when you open it up.
Dave
