pro 96 greenbrook trunk
middlesex , nj
#1
i work for a towing co and we picked up police towing for greenbrook and watchung. i know they are on the somerset county trunked system now. is there a way to set it up where i only get those 2 towns and not the hole county chatter. all i can find on greenbrook is tgid 11440 and Region 3 - Green Brook, North Plainfield, Watchung, Warren 12912 can somebody help its driving me crazy.
N0WEF
Mpls, MN.
#2
Welcome to RR, John!
What you will need to do is program your 96 with the system and TGIDS(Those #'s you mentioned) and then run it in "Closed Mode" which will cause it to only give you what you want to hear. If you already have it set-up, then just change it from "Open Mode" to "Closed Mode" by:
To change from Open Mode to Closed Mode (or the reverse).
Press FUNC + 5 (Bank Open or Bank Closed will display).
Note: The scanner will not stop on any TGID’s which are Locked-Out.
Also, if you haven't DL'd the programming software, these offer free trials so you can see which you like the best:
PRO-96 Software - Win96 - Data Management Software for the RadioShack PRO-96 and PRO-2096 Digital Trunking Scanners
RS RADIOSHACK PRO-96 PRO-2096 PRO96 PRO2096 software data management software PRO-106 PRO106 GRE pro-96 pro-2096 pro96 pro2096 RSPRO-96 RSPRO-2096 WIN96 Scancat Lite
Also, for more local help you may want to post to the NJ Forum. They will be invaluable in help with all things local :)
Have a great day!
N0WEF
Mpls, MN.
#4
No problem, just happy to help out!
If you ever need anything, feel free to message me.
Have a great day!
