Pro 96 Problems
Gibraltar Michigan--US
#1
Hi
I'm having a problem with my PRO-96 scanner, went and bought a new cord, but it still stops scanning every once in a while, flashes low battery--even though always on AC connection, never hardly used batteries, sometimes looses i guess the connection, and have to wiggle the AC cord to get it back. Is what i'm describing normal, or does it need repair?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
#2
Could be the wrong tip on the charger. Page 28 in OM states to use size C Adaptaplug but many test indicate size B may be a tighter fit.
