I have two Pro-97 Scanners and on both of them the right lip of the mounting flange for the
belt clip has broken off after just 3 months of daily use on one of them and after 4 months on the second scanner. It seems that the plastic of the scanner rear case cover which includes the belt clip mounting bracket is too soft and easyly deforms under the pressure of the clip being pulled outwards to place the scanner onto your belt. As the plastic of the
mount deforms, the clip becomes a looser and looser fit in the bracket until it fails. Since
it seemed useless to keep buying replacement rear case covers from Radio Shack, I have
modified both of my Pro-97's by filing off part of the flange and then using a brass plate
inserted into what remains of the plastic mounting flange to attach a belt clip from a Pro-96
Scanner. This is now a very solid and secure fit and seems to be what I hope is a
permanent fix for the poor design of the original Pro-97 belt clip mounting arrangement,
which because of it's un-bolted and loose fit, could only keep getting looser until it failed.
I am wondering what other peoples experence has been with the belt clips on the Pro-97?
John
John
