Pro 97 parts list?
AloTheKiller
Portland, Oregon
I need to order a new keypad board after some battieries leaked all over em. I looked on the radio shack website, and cant find a part list, so I came here for help.
AloTheKiller
Portland, Oregon
UPDATE: It dried off over night, and now all the buttons work again. I think I got lucky this time. Ive also learned not to put alkilines in the yellow case.
Talktech
Pro97 parts list
Exen though the radio is back working, you are setting yourself up for disappointment if you do not clean ALL surfaces that the alkaline leaked on. The traces WILL erode with time and the fix then may not even possible. Such leakage has ruined many computer boards--don't let your scanner be next--tale it apart (or refer to someone more experianced) and clean it--I know it's a pain, but ignoring the fact that the residue of corrosive leakage is still there will not make the residue "go away".Good luck--T/Y
csuh13
SF Bay Area
For all RS scanners, there are usually plenty of replacement parts available. The problem is, you can never access a list of these available "repair" parts from rs.com.
You actually have to go into a store and ask the associate the pull up a list of "available RSU parts" for a particular item. They can then print it out for you to enjoy at your leisure... For instance, here is the list of parts currently available for the Pro-97. If it is listed as "in stock," you can order them at any RS store and it will be sent to you in a few days. If it is listed as "not in stock," it is still a stocked part, but the warehouse is out and they should be replenished shortly. Occasionally it can be listed as "not in stock" for months because A: the supplier is lagging, or B: as soon as it becomes "in stock" it sells out again due to existing backorders...
11318532 DIODE 1N4002 RECT 600V.1A SI $.29 In Stock
10514404 XSTR 2SC4226(R24) SI NPN $2.87 In Stock
11449626 XSTR 2SC4116 SI LO PWR AMP NPN $2.49 In Stock
11840212 XSTR SI DIGITAL PNP/NPN $2.49 In Stock
10539476 ANTENNA,RUBBER 15.8CM $10.99 In Stock
10570166 FILTER,CERAMIC 455KHZ $7.18 In Stock
12357562 CRYSTAL 12.75MHZ $9.49 In Stock
12357570 CRYSTAL 20.945MHZ $8.13 In Stock
12357687 CRYSTAL 12.288MHZ $11.11 In Stock
12430674 COVER BATTERY $3.29 In Stock
12430658 HOLDER ASSY BTRY RECHRG $4.69 In Stock
12430666 HOLDER ASSY BATTERY $4.49 In Stock
12418273 CLIP BELT $3.29 In Stock
12418349 REFLECTOR LCD $2.49 In Stock
12430682 KEYTOP $5.99 In Stock
10720209 JACK,ANTENNA $8.29 In Stock
11840063 JACK,EARPHONE $2.87 In Stock
12228714 JACK POWER $2.49 In Stock
12430690 KNOB SQUELCH $2.49 Not In Stock
12430708 KNOB VOLUME $2.49 Not In Stock
12430617 LED FY1112H-1-TR(D OR E) $2.49 In Stock
12430716 LCD $23.49 In Stock
12430724 MANUAL USERS 20-527 $4.99 In Stock
10881886 IC,NJM2904M LINEAR 8 PIN (S) $2.49 In Stock
10894061 IC,74HC4066F 14 PIN $4.84 In Stock
12100327 IC TK11819M SO6S SMT $4.87 In Stock
12106522 IC KA3361BD SO16S $5.99 In Stock
12357596 IC HD74AC164T SMT $4.62 In Stock
12410775 IC SMT TMP93PS44F $54.99 In Stock
12430583 IC SMT MB15F07SLPFV1-G-BND $16.49 In Stock
12430609 IC SMT EEPROM HN58X24512FPI $17.99 In Stock
12429163 POT VOLUME 50K OHM $15.89 Not In Stock SQUELCH 10K OHM
11717485 SPEAKER 8-OHM 500MW $11.89 In Stock
12430591 PCB ASSY LOGIC $81.29 In Stock
12430625 PCB ASSY RF $27.99 In Stock CONSISTS OF: PCB ASSY RF CHASSIS TOP ESCUTCHEON TOP JACK ANTENNA PM 2X4 NI OR BLK SCREW
12430633 CASE ASSY FRONT $19.29 In Stock NON REPAIRABLE
12430641 CASE ASSY REAR $12.69 In Stock NON REPAIRABLE
Radabaugh
Radio Shack Pro 97 Scanner
Hello im looking for a part for my Pro 97 and i have the part # 12430716 LCD $23.49 In Stock but when i call radio shack store in my area and give them my catalog number on the back of my pro 97 they tell me that the scanner has been discontinued can i can not order any parts is there any way to order this part
KC5EIB
Flower Mound, TX
Part number 12430716 LCD is $15.49 and is in Stock. This part can be ordered from RSU parts at any Radio Shack.
KB3EJV
BERWICK, PA
Is this a regular thing? Meaning if I order the part and put it in will it go bad again, after time?
I am wondering if it is worth it to fix?
KC5EIB
Flower Mound, TX
The two Pro97's I have had since they came out have not had a problem with ther display. These radios run 24 hours most of the time.
Halifax, NS
I'd settle for whatever parts handle decoding digital transmission's on an 800mhz trunked system, my unit works for analog trunking, its just the digital thats not working..maybe you can tell me some of those parts?
gmclam
Fair Oaks, CA
LCDs
Hey guys I was wondering if someone has tried or knows if the lcd is interchangable with say a 92 and a 95, 96/97 ect.?
When it comes to the PRO-97 LCD;
PRO-92 display is different
PRO-93/PRO-95 display is different
I believe that the PRO-96 display is the same.
