Pro-97 problem??
scannerman200
North Central Alabama
When a frequency comes in on my pro-97, their is a humming noise in the background? Anybody else have this issue? & what would cause this. I have tried base & mobile antennas, same iss occurs on both.
GrayJeep
N. Colo.
Every channel? or just 1 or 2?
If it's just a few channels, try the CT mode on those channels and see if it shows a tone. It could be "subaudible" tone transmitted by the station. I can hear the "subaudible" tones sometimes when they are in the 150hz and higher range.
If it's every channel then see if it does it on battery power to check whether it's your power supply.
scannerman200
All channels, even when codes put in on frequencies. Its a low hum in the background. I tried a dc power cord & ac adapter, same issue.
GrayJeep
N. Colo.
Headphones or speaker?
If on speaker then something is wrong.
If on headphones..... there's always a little more noise when using 'phones.
KC5EIB
Flower Mound, TX
The Pro-97, and other scanners, do have a low level hum that can be heard during reception. This has been reported before and is coming from the audio amp. I have not heard where the volume level of the hum has impacted the reception.
