ehssooner14
Hello,
I just bought a used Pro 97 fairly cheap with hopes that it may be an easy fix. The scanner turns on and other wise functions fine however it does not stop on any frequencies. I thought that this may just be due to the antenna connector becoming loose from the board. Any ideas? I was wondering if anybody had and photos of what the scanner should look like with the back taken off so I can try to see if I can find out what the problem is. Any help would be appreciated.
