PRO 97 startup banner changing
stefano225
Just a little twiking I found by mistake if you want to change the startup banner manualy:
press MAN PGM FUNCTION TEXT you get start message Edit first line press ENT when you are done.
gmclam
Fair Oaks, CA
PRO-97 sign-on message
That is not a secret. The instructions are printed in the manual on how to change the sign-on screen message. You can also read about it here in the Wiki.
xpawel15x
It's not in the regular Pro-97 manual, but you can easily find the "secret" keys how to change it online like in the wiki or on this forum.. That's how I found out.
