Pro-97 to computer line-in loud humming
When I hook the Pro-97 up to my computers line-in or mic port (just to make sure it wasn't a line-in port problem) I get a very loud humming that only occurs when the antenna (either stock rubber ducky or my outside) is hooked up. Doesn't happen when you hook up normal headphones nor coming out of the speaker.
I use to hook my Pro-94 up the same way with no problems at all. It seems that as soon as either antenna connection touches anywhere on the antenna hook up on the scanner the buzzing occurs. I've tried several different audio cords to make sure it wasn't a bad cord either, same results.
Edit: This happens even when the scanner is turned off as long as the antenna is plugged in. Happens running on the batteries or the wall plug.
Just wanting to get some opinions on what ya'll might think is causing the problem.
