ARC536: PRO, Uploading new Favorites
Ishmole
Walden, NY
#1
I can't get used to the new upload window on this software.
I find what I need to program on Radio Reference via ARC536Pro, and when I click upload, the new systems do not appear in the "Files Available for Upload" window It is empty.
The files in the "Favorite Files on Scanner" shows the files in the scanner.
How do I get the files in the left pane that I want to program into the Files Available for Upload window?
Mike
Ishmole
Walden, NY
#3
If you did not save the imported system before uploading then there should be a line called 'Unsaved Systems' in the upload list. That file holds the imported data.
Gommert
Butel Software
Thank you, Sir!
I have figured out how to upload. Also, I got my DMR uploads to work. I realized I had to use ARCPRO to do program the DMR systems..
Mike
