PRO106 Display Reads *PC: while flashing STORE?
fourthhorseman
So Far Away....
got this readout on my radio this morning,
never saw it before,and tried searching,but the asteric
is fudging all the results,,
is it a Private Call?
and the number,,not sure if its a radio ID,or
a TGID..
it also reads,TGL/O..so probably a talkgroup?
DonS
Franktown, CO
Looks like a private call with Radio ID (Unit ID) 65395, received via a "Private" wildcard TGRP object at location 0824.
If you press F1 ("TGL/O"), a new private TGRP object will be created for ID 65395, and it will be locked out.
If you press F3 ("Stor"), a new private TGRP object will be created for ID 65395, and it won't be locked out.
If you press FUNC F3, a new private TGRP object will be created for ID 65395, and the TGRP editing menu will be launched so you can make changes to the object's default settings.
