pro164
J-WeB
Bay County, FL
Yeah what's the problemo?
I have a 163, and just programmed it to trunk my largest police department where I'm at. It's like non-stop chatter.
You really just simply press "SCAN", then "MAN", and type in your control frequency then press "ENT". You can press "TEXT" and type in a short description, press "ENT" after. Then just hit the up or down arrow and do the same to type the others in after that.
Once that is done you need to program the talk group id's. Press "PROG", then "TRUNK", and then enter the id #, then press "ENT". You can press "TEXT" to type in a description of it, press "ENT" after. Use arrows to move to another space to program another id.
KC5EIB
Flower Mound, TX
stil can not trunk on my 164 any help
What system are you wanting to listen to?
Is it
Voice Interoperability Plan for Emergency Responders
SYS ID 004 Site 007 (7) County Buncombe with frequencies 866.28750, 866.67500, 867.11250, 867.41250, and 868.76250
john10-4
leicester nc
i programed the trunk freqs ids and talk groups when i hit scan it dont stop i have to hit man then i hear everyone on that talk group
john10-4
leicester nc
pro 164
I just read back over these post and to let you guys know. How all of you helped me Just wanted to say thank you I'm now useing 106 163 and 164 all trunking works. Well thanks again
