PRO2096 Tag Display Confusion
daedalus
Bolivia.NC
#1
I have read on the forum that the tag display defined via WIN96 does not display on the PRO2096 screen.
I am seeing some instances where the tag display DOES appear along with the Alpha Tag. It occurs in conventional mode in those cases where a PL tone is not established in WIN96. Conversely, when a PL tone is specified the scanner display shows the Alpha Tag followed by the PL tone.
I tried everything I can think of but cannot get the Alpha Tag and the overall bank tag to display if a PL tone is specified.
Is this normal behavior or am I just missing something?
DonS
Franktown, CO
#2
That's normal behavior. A bank's alpha tag is only displayed for conventional channels where no CTCSS tone or DCS code is programmed/received. That is, it's never displayed for trunked transmissions, and it's never displayed for any conventional channel whose "mode" is either CT or DC.
daedalus
Bolivia.NC
#3
Wow - that was fast!
Thanks, Don - I have been pulling my hair out trying to figure this one out.
Jack
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
#4
Left of frequency in Win96 a line 3 tag can be very resourceful in identifying either trunk or conventional transmissions.
or
PROG>TEXT to key the info in.
