Pro-652: pro652
chucsan
I have a radio shack pro652 when turned on display says OBJECT ORIINTATED DIGITAL TRUNKING PSR500 it scans channels but no sound
ScannerSK
Weld County, Colorado
It sounds like it needs to be flashed/programmed with a version of the PRO-652 software. I don't believe it should say anything about the PSR500 version on the display when booting. Possibly someone tried to update the software for this scanner with a file intended for the PSR500?
I have a copy of the CPU updater for the PRO-651 which should be the same as for the PRO-652. If you would like a copy just send me your e-mail by private message.
You could also try plugging in a pair of headsets into the headphone jack to see if those work. It could be a dirty or defective headphone jack causing the problem.
Shawn
Chronic
the PSR 500 text is / can be programed when the scanner is programed with software , I know in arc 500 you can make that boot up text say anything you want . I have mine set to say property of and my name and callsign .
trp2525
