pro94
Jerold
Can someone tell me why when I enter a freq. like 154.8675 my scanner rounds off to the next even #. Is there a way I can enter this freq. and have it stay in the scanner why does it round off to the next even#?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Read the specs page in your owners manual (pg 70 in the online pdf). 137 - 174 MHz range is in 5 KHz steps. This will round .xxx5 to .xxx0.
Jerold
Thankyou very much as soon as I read you reply I remember seeing something about it. Seems like I've read this manual 50 times already. Thanks
Jerold
You can tell that i am new to this but really like the hobby. Heres another dum ? how do I get to the page 70 online pdf? Thankyou for yourpatience
fmon
Eclipse, Virginia
You should have a specification topic listed in the contents section of your owners manual. The page won't be 70, but will be in that area. Should be a page or two before the last page.
Specifications
Frequency Coverage :
29–54 MHz (in 5 kHz steps)
108–136.975 MHz (in 12.5 kHz steps)
137–174 MHz (in 5 kHz steps)
216–224.995 MHz (in 5 kHz steps)
406–512 MHz (in 12.5 kHz steps)
806.0000–823.9375 MHz (in 12.5 kHz steps)
851.0000–868.9875 MHz (in 12.5 kHz steps)
896.1125–956.0000 MHz (in 12.5 kHz steps)
1240.0000–1300.0000 MHz (in 12.5 kHz steps)
condor11
raleigh
PRO 94 Manual
I have the same scanner pro-94 and i have read it alot of times. Mostly i've jumped around in the reading.
If a file is brought up in PDF format, you can get to the correct page fastest by using a left mouse click on the scroll bar. Hold down and and the application will show page#/total number of pages in document For instance ----> "45 of 76"
online manual can be found at
http://www.rigpix.com/rs-realistic/radioshack_pro94_manual.pdf
K2GOG
Mid Hudson Valley
whitesox4life said:
where can i find accessories for a pro-94B?
i need the following:
lapel speaker
pouch / case
USB cable with software
any radioshack should have what you need, but if they know how to find it that is another story altogether.
ps. any lapel speaker with an 1/8 plug should work fine. I am not a fan of cases, so I cant recommend anything. As for the software , start by checking out www.starrsoft.com
happy scanning.
fmon
Eclipse, Virginia
happy scanning.
Don Starr does not have software for the Pro-94 which is a Uniden built scanner. You can download ScanCat Lite Plus at http://www.scancat.com/scancat-lite-plus.html The cable you will need is 20-047 from Radio Shack. Radio Shack sold the speaker at one time.
condor11
raleigh
Where on page 70 w/ attached jpg
I see a tablature formatted trouble shooting section on page 70 with no mention of quote.
Maybe, Fmon; ? are you/ is refering to a reference in the table???
Do we have different pdf manuals?
BTW, this is my first time trying to attach a file. So if it isnt attached my post here is less clear.
fmon
Eclipse, Virginia
Your first attach attempt is perfect. And yes, My pdf is different, yours must be for the original 94 because it has the following:
TRUNKING OPERATION
• Your scanner cannot scan trunked system and
conventional frequencies at the same time.
The 94B can scan both conv and trunked in the same bank. However, each page of my pdf has 20-524A but must be an editors error, because the following can only be found in the Pro-94B Owners Manual.
SETTING THE SCANNER TO THE TRUNKING MODE
Simultaneous Trunking
You can also program conventional frequencies in the
same bank as trunking systems.
In either case, the Owners Manual will not have the same page numbering as a pdf version of the same manual. But the contents listings in the Owners Manual should be identical to the appropriate pdf version.
