pro96 and pro 2096 scanner ouestion
ronw
dexter michigan
are there any dsp firmware updates for the pro 96 and pro 2096 scanners avalable for these scanners from the original dsp-voc f1.0 factory version.if so where can they be found and would they help on multi site systems here in southeastern michigan. any help will be appreciated.
N8DRC
Grass Lake
Hello
I own 2 pro-2096's and use a 800mHz yagi to monitor the Washtenaw Co simulcast with good results..
Pro-2096 - The RadioReference Wiki
You will find the lastest updates here for the radio..If you need any help feel free to send me an email..
