pro96 computer trouble
moore2215
New Hampshire
Hi everytime i connect my pro 96 to my pc to use win 96 i get incorrect model thought it was scanner swaped out at radio shack new one doing the same any help would be appreciated.tryed rebooting both scanner and pc several times to no avail.Possible bad connecting cable? Program says looking for header header not found.
rpowley
Rowlett, Texas
Please review the below excerpt from the Win96 Help File and see if that helps.
If the scanner does not begin sending data, or if Win96 displays an error message (e.g. Unable to open the COM port, timeout waiting for header, expected to read back data, etc.), you should attempt the following one at a time:
1. Double-check to ensure that you have the correct COM port selected.
2. Make sure the programming cable is firmly seated in the scanner’s jack and in the PC’s 9-pin connector.
3. Make sure that no other software is using the serial port. The usual suspects include PDA “sync” software, such as Palm’s HotSync. You must either close such software, or temporarily disable it (so that it’s no longer using the port).
4. Under Win96’s Configuration menu, select Serial Port…, and try each of the following:
a. If you’re using a USB adapter, try checking the Extra Write Time option.
b. If you’re using a home-built cable, try checking the Set RTS Line High option. If you’re using a GRE or Purple cable, make sure this item is not checked.
c. If you’re using a one-way cable, make sure the Enable “Readback” Tests item is not checked. (Note: a one-way cable cannot be used to download from the scanner; you can only upload to the scanner with this type of cable).
5. If no combination of the above helps, you should try another computer. There have been rare instances of serial port hardware that cannot drive the electronics in the interface cable.
MitreBin
Sth Coast NSW OZ
Yeah, I use an Icom cable with a stereo to mono plug, to program my Pro-2096 (because I had one!). It worked well initially then started giving "incorrect model" messages, so I looked up the details in Help that RP has shown above and the "4b Home made cable" was the fix for my problem. Hasn't given any further problems since I ticked the "Set RTS Line High" option. - MitreBin
moore2215
New Hampshire
thanks for the quick reply guys iam gonna try looking in the settings also I placed a order for the gre usb model cable today
RDCat
N.W.
im having simalar probs here in colorado
