Pro96Com TG name question
Firetxmi
So I have used pro96com a bit. I used it back in 2007, but have just installed it again and have run it lately.
My question is, I have run it on quite a few towers around here (Colorado DTRS system) and I pulled it up today and was going to monitor a tower I monitored before. Now, it seems as if I have to input all of the names for the talkgroups I have put in because they don't show up with the names when it affiliates. I am sure they are the same tg's I have input the names for before. What am I doing wrong? I saved the system data. I believe I saved everything before closing it down. I even found an Excel file with all the TG's and the names I put in for them.
Do I have to input the names every time I open pro96com to the same sites?
Hope someone can figure out what I am doing wrong. =)
mikey60
Oakland County Michigan
As long as the System ID is the same, you shouldn't have to do that. Check the SystemXXX folder and see what's in there. (XXX is the System ID).
If you're running Windows Vista or Windows 7, you may have to run Pro96Com as administrator to get the files to store properly. (Use the Run As Administrator option in the right click menu from the shortcut you're using.)
Mike
