pro97
elmanc
i have a pro 97 I'm just trying to use my stalker mode just wondering when I'm that mode should the squelch work. thanks
n2mdk
Ames, IA
Yes it works in signal stalker, I see it has rather limited functionality though.
It will stop on some interference while fully open, but doesn't have a full effect, as in conventional
or search modes.
Don_Burke
Southeastern Virginia
Some computers put out enough hash to desense my Pro-97 so it appears the squelch does not work.
Once I get out in the wide open spaces, Signal Stalker works, complete with squelch.
