Proagraming maxtrac with USB-RJ45 cable
bstruel
Israel
HI
a friend of mine gave me a USB-RJ45 cable that he found in a warehouse.
how can i proagram a maxtrac with it?
thnks
cmdrwill
So Cali
HI
thnks
Sorry, you can NOT program a Maxtrac with that cable.
Two reasons, The RSS, programming software ONLY runs in DOS.
The radio does not 'speak' USB.
DOS does not support USB, Neither does the RSS.
cabletech
Puget Sound
And on top of that, the cable could be for a Kenwood.
Bottom line, programming a Maxtrac you need DOS based software and radio interface box, (called rib) with the correct cable for the radio.
Rib and cable can be found all over the place.
