problem choosing player
Columbus, OH
#1
greetings all.
No matter what player I select from the dropdown menu (except java and web player), media player starts. I have winamp and installed on a windows 7/64 machine so i can use the alpha tags. I'm a premium subscriber so I should have access to the player selection. If anyone has any ideas it would be most appreciated. Thanks in advance.
ProScan
Ontario, Calif.
#2
greetings all.
Change the file association for "m3u" files to WinAmp in the Windows Control Panel.
On Win 7, file associations are located here:
Control Panel\All Control Panel Items\Default Programs\Set Associations
