Problem with Astro Spectra
I had something messed up with a scan list. When I was on a mode w/o scan on it worked fine (it an rx only mode). When I turned scan on the radio shut off. This happened with other modes with the same scanlist. I never enabled scan while on the modes. Now when the radio turns on it will not get past the self test. It shuts off right away cause it power up on a mode with the bad scan list and scan is enabled.
Is there a way that I can reset the radio or get it to power up on the home mode so it will stop cycling on and off?
K
kb0nly
Guest
Only thing you can do is hook up to a computer and reprogram, but i have never seen a scanlist problem reset a radio, usually it just says an error message on the screen.
Read, edit, write, move on...
gary123
it sounds more like a corrupted codeplug rather than a scan issue. To get past the cycling you may have to hook up the programming equipment power the radio and immediatly hit program. you can also try forcing the test mode and then program.
Got the radio working again. Thanks guys for your help. For some reason the radio did not like Vtac11 RX only programmed into. The radio would shut off when I would select vtac11. Also if I enable scan on a channel that had Vtac11 in its scan list the radio would shut off.
I removed Vtac11 from the codeplug and the radio is working fine no problems, so far.
gary123
great news , I wonder if the cycling is due to a software issue. But since the line is discontinued i guess it dosnt matter anyway.
OpSec
All your WACN are belong to us
Monitoring the database
The Astro Spectra is the only radio that has actually given me heartburn when programming it.
It's fussy about things that other lines are not, the CPS allows weird (but otherwise benign) conflicts that cause the display to say "ILLEGAL" after programming and it's the first radio I've ever had to replace some of the RF guts (antenna switch, etc) because they let go in a high RF environment. I truly believe that it was a stop-gap radio between the Spectra and XTL series, so Mother M just half-a$$ed it into working.
I'm glad you got your issue worked out.
Thanks Stateboy oops I mean OpSec..
I used to have one that said ILLEGAL after programming aswell. I agree the programming can a pain in the arse sometimes.
mancow
N.E. Kansas
What was the firmware version? Was it a 2.5k narrow capable unit?
