Problem with CPS and Conventionnal Personnalities
paramedicqc
Quebec
#1
Hi there !
I tried to program one of my HT1250LS+ today. I use CPS R06.04.00 AA in pair with a HT1250LS+ (UHF 403-470) TANAPA : PMUE1711B Ver. No. R05.09.13 model AAH25RDH9DP5AN SUPER TANAPA : PMUE1711BAN
I tried to program my departement dispatch center frequencies in it (approx. 22 different frequencies). When I arrived at 18, i can't add new ones ....
Also, I can't enable the MDC for both conventionnal and LTR. I can only enable it for the LTR system ...
Can somebody helps me with that or explain to me how to flash a codeplug from an other HT1250LS+ who accept more frequencies and MDC for both LTR and conventionnal ?
Medford, NJ
#2
Do you have a need for LTR trunking? The 18 conventional channels is a limitation of the LS version along with no MDC on conventional channels. If you don't need LTR trunking you have a couple options open to you.
paramedicqc
Quebec
#3
Oh okay, but unfortunately I need to have the LTR system because it's our primary dispatch system. The conventionnal is a backup and for the areas not covered by the LTR
Sent from my Pixel XL with Tapatalk Pro
