Problem with Littleton Fire/South Metro Fire audio?
tcostello
Washington, DC
Has anyone else noticed it's virtually impossible to understand what's being said on Littleton/South Metro Fire channel?
Strangely, the audio sounds as if it's playing at DOUBLE TIME - too rapid to understand what's being said.
Any ideas?
jimmnn
Colorado
Sounds good to me online and over the air. The Lola voice at the beginning has always been a little weird, if that's what your referring too.
Jim<
captaincraig44
Arvada
If you're only listening to it over an internet feed, it's probably an issue with the streaming computer or the service. OTA sounds fine
tcostello
Washington, DC
I think you're right - it's always over the internet.
Every other agency I listen to on-line sounds fine.
Only LFR/SMFR on Broadcastify is messed up.
I live in Washington, DC (former Coloradoan) - so I can't listen Over-the-Air.
I wonder if the kind person who's streaming the feed could re-boot. (??)
jimmnn
Colorado
Might try submitting a trouble report to the feed host.
Jim<
Spitfire8520
Colorado
I just checked the feed, and I'm getting the same weird stuttering and accelerated audio problem. I've submitted a problem report in the event that no one else has done so.
N2PDQ
Im the feed provider. I did receive the trouble ticket. I will reset the software, and will bring it back to normal. For some reason the software has issues with the programming cable i have plugged into the scanner. When its disconnected it will run fine, but when i leave it plugged in, i have issues about once a month. I will be upgrading the pc its running on later this month, so that should cure the small issues.
Dirk
