Problem with TGM
73cuda
Florida
I've switched my feed over to an older PC to be a dedicated feed server to RR. I have everything setup identical to the PC I had been using for the feed (this PC). I can stream the audio to RR just fine but when I try to activate Serproxy and TGM, Serproxy gives the following message: "Failed to open comm port - connection refused".
The PC has only 2 comm ports available, 1 and 2. 1 is fine and it's the one I'm trying to use and 2 has an yellow "!" on it but says it's fine.
I've compared all settings from between the PC that they work on and the older PC and I just don't know what I'm missing and have not seen that connection refused on serproxy before.
Any ideas ? I need some help.
Thanks,
Steve
